DarkSideA8
- Apr 13, 2005
I am able to run the demo with my rig at 1024x768 on medium settings. It is more than just "playable" -- in fact it runs smoothly (all except for the first cut-scene video: the actual gameplay is fine) and looks great.
I plan to start pushing the envelope with higher settings - but don't know how to check the FPS to compare what works and what doesn't.
Anyone know the in-game code - or whether it would be better to use a different FPS checker?
(--Also: does anyone know if the game is better optimized than the demo(i.e allows you to run higher settings than the demo)?
Sys:
Athlon 64 3000+ (Socket 754)
MSI K8N Neo Platinum
3Gb PC3200
Geforce 6800 GT(pushing a good 19" CRT)
Audigy 2 ZS
(I realize my old dinosaur doesn't impress - but it is a solid "golden oldie" )
-- In any event, since I'm not able to upgrade any time soon, does anyone have suggestions on what settings to use to get a good balance of performance / eye-candy?
Sys:
3Gb PC3200
Audigy 2 ZS
