Crysis graphics glitched
TiTaNs_ReVeNgE
I just built a new computer for my parents/brother, it has a 6750 on a p35 mobo, 2 gigs of ram, and an 8600gts. It's running XP Home, and the latest drivers for everything. Everything is at stock speeds, and Crysis is running in 1024x768 with everything on medium. It looks like this,
If this doesn't work for anyone, basically certain objects don't show up at all, like rocks, the character is transparent, and if i look down the screen turns gray. Any suggestions? This is the demo btw.
The latest drivers doesn't always mean the best drivers, which ones are you running, maybe try some of the betas or revert to some older ones
I have seen similar things with an 8600gts and splinter cell
Forcing AA and or AF from the control pane? If so disable it, set both options to Application Preference in the control panel.
Sorry there Brent, I mislead you a bit. I went back and completely cleaned out all the driver files with driver cleaner pro, then reinstalled the 169.09 drivers and it worked! Thanks for the help kind sir.
Anyone know why I am having trouble with Crysis in DX10? The first time I launched it, it worked fine but once I enable FULL SCREEN, the thing freezes just before the EA logo shows up.
DX9 works like a charm.
8800gt with the 169.02 drivers.
try turning off different items in the video options of the game. I had the same problem when the airplane was flying by and parts of it were invisible :rolleyes:
go back to default video options and go from there
