Crysis Editor
sandbox editor is on every original Crysis install disk, not just for 64bit.
Copied straight from the readme on said disk.
Sandbox2 Editor Installation
Crytek’s Sandbox2 ‘What you see is what you play’ level editor comes
free with Crysis.
To install the editor browse to the \Sandbox2 folder on your DVD-ROM
using Windows Explorer, and run the "CryEngine 2 Sandbox" installer.
In order to install and use the Crysis(R) Sandbox Editor on Windows
Vista(TM) it is necessary to disable User Account Control (UAC). To
disable UAC, follow these steps:
1) Go to Start \ Control Panel \ User Accounts
2) Click the "Turn user account control on or off" option
3) Click continue on the UAC popup
4) Uncheck the box next to "Use user account control (UAC) to help
protect my computer"
5) Click OK
my bad. my roommate has crysis and he was bitching that the editor only works on 64 bit. guess i was relaying misinformation. sorry.
I like the editor, but enemies do not show up? I put everything else and it shows up when I hit play.
Any type of character I try and add never shows up. Tips?
It comes with the game and with the demo... Good stuff
I had that character spawning problem, I discoverd that if I was spawning within site of my enemies unless they were in the default file (never started from scratch) I wouldnt see them until I went away and came back...
No, I am pretty good at searching for stuff, but this is really annoying!
I just installed it, so it has DEFAULT settings as it comes. There are NO enemies when I load a map in the editor. I loaded the demo map, I can see the guys there when editing, but after I hit CTRL+E and CTRL+G the enemies, AND JEEPS disappear! There is not one site or video on youtube that shows how to enable this.
Someone? Everyone else has the damn thing working it seems, crazy.
It works best on 64-bit operating systems. Here's what it says in the readme:
"Warning: Running the Sandbox Editor under a 32bit OS can lead to
instabilities with production size levels due to the low amount of
virtual memory available. Though the Sandbox Editor can be used in
this configuration to learn the feature set its use on a 32bit OS
is not supported."
Anyone know how to make the characters show? I've even skimmed though crymod.com's forum and none of the tutorials show anything about this....
