Crysis 3440x1440 issues
bencho
Hey guys,
Just got a 2080 and wanted to fire up Crysis in all it's glory.
Ran into an issue - trying to set 3400x1400 in full screen doesn't work properly. I also tried editing the config file and no luck. It just wont accept the resolution. At best it works in windowed mode but then its shifted off the screen a bit.
Is it just me or is there a bug I'm not aware of?
Just use the console to manually change the resolution (I believe the commands are r_width and r_height). You can also add this to the game's config file.
