Crysis 1.2 Download
i'll tell ya this patch is amazing.
pair it with them Xtreme G ATI Drivers. wow, now any ATI card is a powerhouse!
Never saw they other posts, thanks for the headsup, hope performance is improved.
In-game Performance Results anyone??
Need to know if this is worth the download..i pay an arm and a leg in my country for bandwidth.
Have they solved some of their copy protection issues with this patch?
I have never had issues with a game like I have with this one. I had been playing it for a few days and then the next day it complains that it can not verify itself. Turns out this error happens if the copy protection detects software running it does not like. Course I tried killing just about every app I had running and could not find the culprit. Finally I just rebooted and it worked again. However I suspect I will get this error again.
I did find that apparently Process Explorer(procexp) will cause the error I got, however I was not running that app at the time, it is installed though. I do not have any CD emulator programs which is what I would think this program would be most upset about :(.
Also do they plan to ever remove the requirement to have the damn DVD in the drive. That is an extremely annoying copy protection, I hate having to dig out the DVD when I want to play.
^^ That's why I bought it, and cracked it.
I have no qualms with doing so, if they're going to be total bastards about that crap :eek:
I don't even have a DVD Drive, just a freaking USB one that I pull out to install crap.
SecuROM doesn't care whether you have things like Process Explorer installed or not, but it *does* care if you've run them since booting up your computer (which is why you had to reboot after quitting Process Explorer).
I sent a detailed bug report to 2K Boston/2K Australia and SecuROM complaining that the SecuROM blacklist check has an incredibly negative impact on the install process of Bioshock, because it comes at the very end of the install (which takes about 20 minutes), and if you have so much as run Process Explorer at any time since booting (a utility which is now owned and distributed by Microsoft I might add!) the entire Bioshock install process will stop, and then uninstall Bioshock with a very generic SecuROM error message reported. On top of that, SecuROM's web site (at least at the time of Bioshock's release) didn't explain that you had to make sure not to run Process Explorer since you booted your machine, and as a result I re-tried the install process four times, since I used to have Process Explorer run minimized and hidden with the CPU and I/O history tray icons active on startup, and was assuming that simply quitting it was enough for SecuROM (it's not). I can't remember the last time I've been so annoyed at game copy protection... I even scoured the manual and checked the box to see if I'd missed some warning about it, but there was nothing (nice way to treat paying customers, let me tell you).
And I never received a single reply from 2K Boston/2K Australia or SecuROM.
I had a similar issue. I couldn't ever even get the DEMO to run and that has no DVD to even check for! By the time I realized what was actually going on I was too frustrated and just uninstalled it. I was really psyched about playing that game too from all of the hype it received. Why in the hell do they really care so much about PE? I know it can do hex dumps and whatnot...but so can a lot of other programs out there that are far more dubious. Hackers will have their cake and crack it too. By cutting off anyone who runs a widely used -and extremely useful- utility is just asking for problems.
does not increase FPS but gameplay is ALOT smoother i think those memory leaks they fixed were the cause of sluggish gameplay is big firefights, the game now runs where i want it,
i may play throught it now
Thanks for your response, very odd that it cares that the process was even run since boot. That explains my issue. Wonder how it determines that a process ever ran during that session?
I agree completely.
I can tell you why they bother copy-protecting the demos... they are worried that if they don't, crackers can use the demo exe to figure out how/where the copy protection works in the retail exe and thus they reason that by protecting the demo exe they are protecting the retail exe. How well this works in practice, I don't know, but it sure makes some demos annoying, especially when they don't tell you up front and clearly what's blacklisted.
If a publisher is going to use borderline invasive copy protection, it's the least they can do, rather than have a user waste their time, get annoyed, and maybe just give up.
I bought Oblivion because of it's liberal Copy Protection. Guess which games I *didn't* buy?
Fuck you Secure Rom.
hey thanks for the input
Is there a way to install the patch without the DVD? I'm at school and I don't have the damn thing with me.
This one didn't ask me to insert the DVD to install it, but I did put it in to play the game (although I'm not even sure if that was required). I'll leave it at that as they may prohibit discussion of using no-CD hacks on here.
Just discovered.... the securerom bullshit thinks my LG GGC-H20L sata DVD drive is in violation. Apparently the driver for doing sata optical microsoft has triggers "Conflict with Emulation softwre detected".
I have no emulation software of any kind on the machine and never have. So I have to put the old IDE DVD burner back into the system, to hold the DVD, in order to play the game.
At least finally by doing a "repair" operation from the Crysis disk, I was able to get the patch to install past the infamous error.
