Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I must have misplaced my Cyrorig H7 Intel backplate. Does anyone know where I can get a replacement? Or can I use another company's cpu cooler backplate?
Probably the best way to get one is contact Cryorig customer support, explain your problem and ask if they can help. I assume you registerd your cooler and have the 'credit card' registration card fo rthe number.
sftp://wilburg.dyndns.org/
