Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Anyone own this? How's the noise? I've been looking at either this or the Noctua NH-L9i; looks like the C7 might perform better, but I've been unable to find a noise comparison between the two.
I was just looking at reviews for this, a couple of days ago. Its pretty quiet. Noctua's L9x65 is a bit taller, but a similar low profile design. and only beats this by a couple of decibels. The Cryorig is probably one of the better values for low profile coolers. Especially if you are using a CPU which is lower TDP. Like a 65w or something.
But if you have 10 extra dollars...
I would also look at the Silverstone Tek Argon AR05 2 heatpipe and and AR06 4 heatpipe version (a bit taller, but still low profile). Both generally cool better than some other competing size heatsinks.
The Silverstones and the Cryorig are within a couple of degrees of eachother, with a stock 4770k. But overclocked, the Silverstones beat the Cryorig by a pretty large amount. 10 - 12 degrees. But that may not matter, if you are running a low TDP, stock CPU.
