Crt's W/ DVI
Shapeshifter
I had no idea that they made or had made crt's with DVI, but Ive seen an IBM P275 that has just that.
How would that compare to say BNC connections? just as good? better? not as good?
DVI will be digital, BNC will be analog component. Make sure your card will support the monitor, and vice versa. Analog component will be a bit better then straight VGA.
Luck
BillR
well I know all that, and the aiw 9800 pro only has a dvi hookup (I have to use an adaptor if I want straight vga)
What im wondering is how dvi compares to bnc in terms of quality?
I doubt you will have a problem with the ATI. I have several of their cards and even hooked to my HIDEF TV with DVI I can come up with a combo setting that works pretty well.
I'd think you should be ok
Luck
BillR
