I've been searching around and have only picked up bits and pieces. Can anyone weigh in on the picture quality of a CRT on a dual-dvi card using the included DVI-VGA converter?
Or am I really better off buying a dedicated DVI-A to VGA cable? Monoprice has one that looks good but I'm not sure on the quality and could use some recommendations. Monoprice Cable
It's a NEC FE2111SB and I'll probably have it running at 1600x1200 or 1920x1440.
