i thought really high refresh rates(above 100Hz) actually made things fuzzy on a crt. also what would be the point of an lcd that could do 120Hz?blksun000 said:Personally I wouldn't be without my CRT right now. Don't get me wrong, I think LCDs are great (I do have a couple), but if you want to run a really high resolutions with very good refresh rates you need a lot of change. I run mine at 1600x1200 @ 120Hz and it is impecable. I would run it higher for it's native is a good bit higher, and it can still handle something like 80-100 hz, but it gets to the point where everything is way too small for normal work unless you up the font sizes. Anyway, I have a Viewsonic P91f+ and it is amazing. When it comes to running at high resolutions with fast refresh rates, if money's an issue CRT is the way to go. Though, with everyone talking about this, does anyone know of an LCD that has a native resolution above 1600x1200 @ 120hz and is under $600? That would be great. It would have to be at least 21". Anyway, i'll check back if anyone knows any good ones. Good luck with your purchase.
