Hey, I'm having a couple of issues, and I wanted to see if it could be fixed or not. First, the power in my apartment is kinda sketchy, so I bought a decent APC brand ups with voltage regulation, hopefully to elimate my problems; didn't fix it.
There is slight ghosting of the image to the right, which I recognize is an issue of crts that are aging. (This is an IBM p202 Trinitron, 21")
The serious (and irritating) issue is that periodically the screen will flicker, kind of how the image behaves when you degauss it. There really isn't a pattern to it, it will just vibrate, then perform normally. It is much more noticeable/frequent at higher resolutions/slower refresh rates.
Is this a result of the aging CRT, and I should suck up an replace it? Or, could it be a problem with the cable from the vid card to the monitor? I can easily replace this, as it is technically a professional workstation monitor, the cable is standard and replaceable. Should I try shielding it cable or buying a shielded cable? It isn't running that closely to any power cables, but I don't know what is in the wall behind it...
Thanks for any advice!
J
J
