CRT: difference between 1280x1024 and 1280x960
unearth01
I have a 19" crt(930sb). Mitsubishi recommened 1280x1024
but i have read that 1280x960 is better
what is better or best
1280x960 is better because that is the correct aspect ratio (4:3) for that screen. Using the monitor at 1280x1024 will result in a slightly "squished" image vertically.
there are not any appreciable differences, using 1280x960 there is some deformation on the screen, but is marginal.
Of course 1280x960 because that is with right aspect ratio 4:3 as your CRT, i have always wondered why in hell they even put this 1280x1024 distorted flat shit resolution on 4:3 aspect CRT as recommended. Its all another ball game if you are using another aspect ratio like 5:4 like some LCD's have.
1280x960, since it's 4:3.
That screen will do 1600x1200 @ 85Hz though, so you could crank it up higher. I generally find that a little high on a 19" for normal desktop use, but it'll look quite nice in games your system can handle at that res.
If it'll let you, you might also give 1400x1050 a try. It's kind of an odd resolution, but has gotten more common since various companies started using it on laptops. That's actually my preferred mode for 19" screens since it's the closest to 100 dpi on a 19". I've got 3 monitors in mismatched sizes and I like things to be about the same size on all of them.
A 4:3 screen with a 20" viewable area is 16" x 12", so at 1600x1200 it's at 100 dpi. The viewable area of a 19" w/ an 18" viewable is roughly 14.4" x 10.8" I suppose if I were really anal I could always add a custom 1440 x 1080 resolution.
I haven't mucked with ATI's drivers lately, but I know the current NV drivers have a custom resolution feature.
Ever wonder why that 80 dpi setting was in Windows?
Code:
Viewable  120 dpi   100 dpi   80 dpi    75 dpi
20"       1920x1440 1600x1200 1280x960  1200x900
18"       1728x1296 1440x1080 1152x864  1080x810
16"       1536x1152 1280x960  1024x768  960x720
14"       1344x1008 1120x840  898x672   840x630
13"       1248x936  1040x780  832x624   780x585
12"       1152x864  960x720   768x576   720x540
11"       1056x792  880x660   704x528   660x495
