Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
So i just set up a dual monitor rig comprised of a pair of AOC Spectrum 7 Vlr CRT's. One works great, but the other is quite blurry and hard to read. There is a sticker on it saying it was repaired in '03. Is there any way i can fix this myself?
the only refresh rate i can get at 2560x1024 is 60 herts. The lowest resolution i can go to that will utilize both monitors is 1280x480, and i do not see any improvment in the bluriness when i change the refresh rate in that or any resolution between the two.
Lol, i was doing this all through the nVidia console, and now that im doing it through properties, everything is fine, except for the fact that i cannot extend the taskbar onto the second display
i can only have the same resolutions with dualview, and the taskbar does not extend to the second monitor. With horizontal span, the taskbar does extend, but the first monitor's resolution cannot be changed to match the second.
Btw, the second monitor is still blurry.
EDIT: For some strange reason, the monitor just got better by it's self!
