Z
Zinn
Guest
Anyone using this? I bought it yesterday and have been playing around with it. It's a little rough around the edges, but it works well enough to play any of the Steam Engine games and plenty of other games.
I've been playing a lot of Team Fortress 2, and it works pretty damn well. There are a couple of bugs in some surfaces with shaders, such as water (see the screenshot), and every now and then the game crashes between maps. Otherwise it's perfect and it's fast enough on my 8600 GT at 1680x1050 and mostly max details to not have to worry about the framerate.
The other Valve games seem to run great, although all of them run in only DirectX 8 mode, because there is a bug in Apple's video driver preventing the shaders from working properly in DirectX 9 mode. Because of this, shaders such as bumped mapped surfaces and water tend to render wrong or look ugly, but otherwise the games run well.
The fact that these games can run at all on the Mac and near native speeds is nothing short of amazing. There are just a couple of rough spots that could be ironed out in the next couple of patches, and then this software would get my full recommendation. As it is, it's better for if you have time to tweak around with stuff, since it's not a trouble free solution. It's definitely worth more than a passing glance though, especially if you hate dual booting.
