Crosshair IV memory..?
Alex3951
I'm putting together a new computer and all I have left to pick out is Graphics and Memory.
This is what I have so far
AMD Phenom II X4 965BE
Crosshair IV
CM690 II advanced Case
Corsair TX750W 750W ATX Power Supply
Corsair Cooling Hydro Series H50 CPU Cooler
I know almost next to nothing about computer memory and have been having trouble picking memory to go with this setup. Reading different things about different memory compatibility is getting really confusing.
So far, I've picked out this memory..
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145198&Tpk=Corsair XMS3 TW3X4G1333C9DHX
Based on the C.H. IV's memory compatibility list, what would be the better choice on memory? Any recommendations?. I don't overclock and my budget for memory is probably max $180. I'm looking to get 4GB of Ram.
to slow at 1333 whit those timings. if your not going to be OCing you should get some ram whit tighter timings and drop the h50 not much point of getting a $70 cooler not to oc when the stock will work fine, spend it on a better vid card. as for the ram just about any ddr3 should work fine (don't get over 1600 if your not going to oc the bus) get some thing whit cl 7 or 8 max
