Crossfire with pci-e 2.0 (x16+x4)
doug_7506
System specs in rid.
I was thinking about adding another card to my rig in the not so distant future.
My current mother board only supports crossfire and pci-e 2.0 with x16 and x4 slots
I currently have a 670. I was thinking about trading ti for a 7970/7950 so I could go corssfire, but I am worried about the second lane being only x4.
So I have two options as I see it if I want to add another card.
Option 1:
Sell mobo and buy a mobo that supports 2x x16 lanes. ~$100
Add another 670 ~350
Option 2:
Trade 670 for 7970/7950 ~0 - 50
add another 7970/7950 ~350 - 400
Run them at x16/x4
The problem is not that the lane runs at x4, the problem is that that lane runs through the Z68 chipset instead of being connected directly to the CPU like the x16 lane is. That is where your performance hit comes from. Not sure how big the performance hit would be though, I haven't seen any actual numbers.
Thanks for the info. Do all x4 lanes run through the chip-set or is there something about the board that tells you this?
If I were to buy a new board how do I make sure they lanes connect directly to the cpu and not go through the chip-set?
The fact that the board uses the full 16x for the primary slot only tells me that, since I know that the Z68 chipset provides 4 PCI-E lanes.
All boards z68 boards that use x8/x8 will have the cards directly connected to the CPU, since the lanes are shared between the cards. Some Z77 boards also have the option of doing x8/x4/x4, although they usually only allow this with a PCI-E 3.0 IB processor.
That board does x16, x0, x4 or x8, x8, x4. That's what that wording means.
TY for teaching me this stuff.
So anytime we have a board that does either x16 on a lane (or multiple lanes) or splits from x16 to x8/x8 with two card we are going to have a board that goes directly to the cpu? Correct?
Pretty much yes, in the case of LGA1155. If there's two slots that run at x16/x16, that board uses a duplex chip between the CPU and GPUs, and is also able to run x16/x8/x8 tri-SLI and sometimes x8/x8/x8/x8 quad crossfire.
On a 6870 (requires, I would imagine, a whole lot less bandwidth) the fps difference was 5fps
http://www.overclock.net/t/967533/crossfire-x16-x4-vs-x8-x8-comparison
going to a 7950/7970 how much more of a difference would it be?
More Data:
http://www.insidehw.com/reviews/graphics-cards/6178-crossfire-x8x8-or-x16x4-the-ongoing-dilemma
In both of these cases, the performance hit is not that big of a deal, but these were 5x series cards and 6x series cards. Wondering how the cards of this gen would compare?
It really depends a lot on the game. If the game relies heavily on data transfer between the CPU and GPU, the effects on performance are going to be bigger than a game that doesn't rely on as much transfer. So a game with low transfer requirements will have a similar performance decrease, while games that have higher transfer requirements will have a greater performance decrease.
Also, single monitors are not as likely to suffer from the performance decrease as multimonitor setups, as [H]'s testing at x16/x16, x16/x8, x8/x8, and x4/x4 have shown.
Also, as the OCN thread noted, there's the issue of minimum FPS and microstuttering.
