Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well since there seems to be no one home or alive today, I just went ahead and ordered the ASUS Top 3870 @851 speed and hope it will work with my gigabyte 3870 @775 speed. This is my first attempt at crossfire and there seems to be no one there about this subject so I will just take the plung and die I guess. One of the problems that I had seen was someone that had to bridge 4 slots there bridges were too short but I think the ones I already have can cross 5 slots so it should be OK. I will see in 3 days or so when newegg sends me the card.
I will put the Asus 851 in slot 1 and the Gigabyte in slot 2 and oc it to 851 to match the speeds. That is if it will hold up. I can always put my thermaltake HR-03 on it to keep it cool. Then I think I will oc the Opty 185 along with the memory which I have running slower than it is rated. So all in all it should work out good and stable. This should last until the Intel 8 core @ 8ghz come out at xmas or Feb of 09. Then it will be time for a major update along with all the new super graphics comming out about the same time. The new tech should be in by then. not m gates.
