crossfire unigen results?
glw165
anyone have any unigen results, so i can tell if i have a problem with my 6970's
need see a screenshot thats remarkable with all at high tessalation extreme
Much lower scores with everything maxed. About the same as I get with a single card on default settings.
looks like my frames are bout the same as the 580's when tess is off, like the 1 guy mentioned earlier tessalation kills these cards
What is the point of this post? Why not post your results?
I ran this on a single GTX 580 before in a i5 2500k system and the scores were similar to a single 6970 in a i7 920 @ 3.6Ghz. I also know a friend with a 4.2GHz setup and SLI EVGA 580's gets about 2400 with the test as I posted with my 2180 results. That is with Tess on normal, the default setting. I don't know about Tess on Extreme.
Good to hear. What are your scores now. I am considering adding another 6950 to my setup.
yes but ur cpu is less and more score, doesnt make sense to me, i guess 570 lil more ass to them
570's are the direct competition to the 6970s, so it makes sense the scores are similar. The 570s win in some situations, the 6970s win in others. Just depends on the application/game.
His CPU is overclocked to 3.8 ghz, which would be a match for your CPU at 3.5 mhz. Unless Unigine performs faster with 4 additional threads (doubtful).
well i got a much higher score on the 2.5 vers but i cant open after i saved it to view says unsupported format wtf?? 1710 score or something like that
