Thermite Paste
- Dec 17, 2003
I've been struggling with this issue and figured I would ask [H] for advice... I have two XFX 7950 DD's in Crossfire, and no matter what I do card 1 (the top card I'm assuming) will keep increasing in temperature until it hits ~100c and everything crashes. The problem doesn't seem to follow the card as I've swapped them and it's still always card 1 that heats up. In addition, neither card is overclocked (aside from the small factory boost that AMD released a while back) and the fan ramping is set much higher than stock via afterburner.
I don't think there is an airflow problem, as the intake is unobstructed and the 120mm fan blows the air directly into the cards. Everything I do only seems to slow down the temperature buildup, but even when playing something that doesn't push the cards past ~50% utilization like Borderlands 2 is enough to make the system crash after enough of a marathon. Any game that makes 100% utilization on both cards is enough to cause the temps to max out within 15 minutes. All of the things I've tried (mesh side panel with fans, etc) only slow down the problem, but no matter what i do the top card has a noticeably higher temperature than the bottom. I'd love to go with a full watercooling solution, but I simply don't have the $300+ that it would take to do it properly right now.
Pic of how things are currently set up:
