I just bought and installed a second ATI 4870 512MB graphics card and am setting up crossfire however I have a couple questions about setup.
At 1920x1200, will I need 2 crossfire bridges installed or just 1 (as of right now I only have 1, but I can buy another). I've seen people recommend either.
I was also wondering how I should go about connecting the cards to the power supply. The card requires two 6 pin connectors. The card came with a couple 1-to-1 6pin to molex connectors.
These connecters are 1-molex to 1-6pin connectors; however most connectors I've seen require 2-molex to 1-6pin.
Is it okay to use the 1-to-1 connectors provided by the manufacturer or should I use the 2 to 1 connectors (1-to-1 is obviously preferable from a cabling standpoint)?
I was also wondering if I could get away with connecting both 6 pins to their respective 1-to-1 converters, and then connect both of those to a Y molex connector which would only take up 1 power supply molex output?
AKA is this possible:
6pin-on-GPU--->6pin-to-molex-converter--\\
__________________________________y-connector-->PSU
6pin-on-GPU--->6pin-to-molex-converter--//
I understand if this is not a good idea, i just hope that i can at least use the included 1-to-1 6pins to molex converters even if I have to connect them to different PSU outputs.
