Does anyone know if you can run 2 3870x2's and a single 3870 all crossfired? There are enough physical crossfire connectors.
That would be 5 GPUs. Max is 4.
No I pay for power but like I said before the computers don't use that much power and we don't leave them on 24/7 my gameing computer with tri sli 3 monitors multiple hard drives etc and it only sucks 600 to 650 under full on gameing. Just trying to use what I have to the best, maybe I should use the two 4870 1gigs I have they just seem so hot and power hungry.
The 3870x2s almost definitely use more power than a 4870
And that 600-650 figure is maybe the computer itself, no way that includes monitors haha.
stock 920 cooler with voltage at 1.4 and heatsink is barely warm
i7 920 at 1.4? Dude lower that, you shouldn't go past 1.35. I don't even know why you have it that high. I can get 4ghz at 1.275. Who cares about heat at that point there's a limit to the amount of current you can push through a electrical component.
