Crossfire Profiles
Greatone123
Heres mah problemo
I use multiple monitors with 2 video cards, I understand with crossfire the other displays besides the primary is disabled... well... that's where the problem comes in.
I WANT them to disable but ONLY when I start a game or someting, which I have the profiles set so that when they start it enables crossfire or so I would assume that since it won't let me say, enable crossfire when I play this game.
But when I try to start a game, my monitors don't turn off, just a bunch of flashing and I go into CCC and crossfire isn't enabled... I know I can open CCC every time enable and disable but isn't that the point of Profiles to be able to NOT HAVE TO go into CCC to change setting EVERY TIME you use said program?
Anyone wanna assist in this issue?
Windows Vista 64-Bit
AMD 4800+ X2 AM2 Brisbane
2GB Patriot DDR2 800
ECS KA3 MVP 580X Crossfire MB
2x x1950 Pro 512MB
2x 80GB Seagate SATAII HDDs
SB X-Fi Xtremegamer
3x Acer 19" WS LCDs 4320 x 900 resolution
