First my system specs:
AMD FX-57
Asus A8R32-MVP (Bios 0404, thought same issue on 0311)
ATI X1900 XTX
ATI X1900 Crossfire
2Gb OCZ PC3200 Platinum
Audigy 2ZS
NEC 20WGX 1680x1050 @ 60Hz
Windows XP SP2, .Net 2.0
700W FSP Power supply, Crossfire Certified
When I run Oblivion, I see a huge increase in framerates when running in Crossfire mode, it's amazing. But when I run CoD2, Tomb Raider Legend or Ghost Recon Advanced Warfighter (Demo) I see no difference in my framerates between Crossfire and single card mode. I'm using fraps to record framerates. I might see 1 or 2 fps difference, but I think I should be seeing a much higher increase in my frames per second with a Crossfire setup. I know that Oblivion has an AFR profile, not sure on the others. Even if they don't have one though, either the supertiling or the scissors mode should be in effect and giving me a performance increase. I'm not seeing any. I've tested this with both AA enabled and disabled, not going above 6x as I realize this enables SSAA and disables any performance increase in Crossfire mode. Am I missing something here? Can anyone explain why I am not seeing any benefit to having Crossfire with any of these other games? I know it doesn't make much difference at lower resolutions, but isn't 1680x1050 high enought that I should be seeing some performance increase?
AMD FX-57
ATI X1900 XTX
ATI X1900 Crossfire
Audigy 2ZS
