Crossfire overclock reseting to default
Drangueos
I have 3x HD 7950s
1 is a Gigabyte and 2 are MSI
I'm using afterburner to overclock them, when I overclock all 3 cards clock raises but after some time the primary card's clock goes back to default (I'm using the gigabyte as primary)
Driver is not crashing or anything like that, if I overclock by 1mhz it still resets to default, even if I underclock the cards the primary will goes back to default.
AMD Overdrive is not enabled on CCC panel.
I'm not sure if it is due mixing different brands and msi afterburner.
Afterburner reads the Gigabyte card as: "AMD Radeon HD 7900 Series" and the MSI cards as: "MSI R7950 series"
"Synchronize settings for similar graphics processors" is enabled
I thought about using the MSI bios on the Gigabyte card, but I would prefer to find another solution before trying that.
Any help would be appreciated.
Are your overclocks saved under a profile and enabled at startup on afterburner? I'd also try other software like sapphires trixx or possibly evgas precision software. If that fails, like you mentioned a vbios flash might fix the problem.
