Retroactive
- Sep 24, 2005
Hello folks,
I am a newbie at setting up a discrete crossfire installation. I had been using an all in one solution 3870X2. OK, I purchased 2 Radeon 4850 cards and would like to know the procedure for setup in a crossfire arrangement. I thought this would be discussed in the manual on the supplied CD-ROM - it wasn't unfortunately. And the latest procedure I found on ATI was for the 3800 series which apparently has a different pin-out arrangement than the 4800 series cards.
Now I do know that I have to install these in adjacent PCI-e slots and connect the necessary power connectors. But what do I do with the crossfire connectors themselves?
I see that each card has two sets of male connectors at the top of the card. Do I connect just one crossfire jumper/connector between the cards or do I connect two crossfire connectors between the two cards?
If it is just one connector, what set of pins do I choose? The one closest to the vertical riser or the one towards the middle of the card?
Once I have the crossfire set up - which is the master card? And which video port do I use? Or are all video outputs live and providing an output signal?
I assume that the software installation is as simple as loading the latest drivers and there is nothing special that needs to be performed within the Catalyst Control Center?
Oh one other thing - I do have a crossfire capable MB (it is a intel X48 chipset), I am guessing that there is nothing I need to enable or change within the Bios?
Any guidance or installation procedure would be helpful. Thank you for helping a crossfire newbie out!!
