Crossfire bridge stupid question
Michaelius
I'm planning on building CF rig with 2x2900 pro 512/256 however those cards came with no CF bridges so i have to buy them separatly.
Are all bridges same length and quality and will any of them work with 2900 ?
Mobo will be either Abit AW9D or DFI RD600 chipset one.
The crossfire bridges that came with my reference-designed 3870 cards are flexy, (like ribbon cables you can only twist on one axis) so they work between 3 slots or two depending your motherboard setup. i don't know if anyone sells non-ATI reference crossfire bridges, but if you post a link to what you're looking at, i'll tell you if it's the same or not...
i'm fairly certain that all crossfire connectors are otherwise the same (ie. whatever works on 3870 will work on 2900pro, etc.)
