MakubexGB said:Yeah, if anything your system will just shut down. But I would recommend getting a better PSU just to be sure of stability and leave a little headroom. Also check out the XClio GreatPower 700W or 750W.
It would be if both PCI-E leads ran out of just one 12v rail, but as I understand in this PSU and the GameXStream they are divided. I'm still not 100% sure, but if this is in fact true then these new Quad 12v rail PSU are better suited for CrossFire.Spectre said:A single large 12v for Crossfire is probably a better plan.![]()
MakubexGB said:It would be if both PCI-E leads ran out of just on 12v rail, but as I understand in this PSU and the GameXStream they are divided. I'm still not 100% sure, but if this is in fact true then these new Quad 12v rail PSU are better suited for CrossFire.
Therefore PSUs like the XClio GreatPower and OCZ GameXStream are better suited for CrossFire?jonnyGURU said:Yes and no.
PCI-e-1 is on 12V4 by it's lonesome.
PCI-e-2 is on 12V2 with CPU-2.
So if you're going to run SLI/Crossfire and your board needs an 8-pin EPS, I suggest NOT using the 8-pin and only using the 4-pin, since GPU's are requiring more juice than CPU's these days.![]()
