Deacon_Jones1988
- Dec 8, 2012
I have 2x7970s in CFX, During Idle and gaming I have noticed a big difference in temp on the cards. For instance the top card is always warmer then the bottom card. Right now at idle my top card is idling at 36*C and the 2nd card is at 28*C.
The fan speeds on both cards are at 55%. I have a fan installed on the inside that is at the end of my 2 gpu's its the bracket that the Phantom 820 has that tilts. Its attached to the HDD/SSD cage.
Would the fan be causing my heat variance? (Because given it's location the air from the fan would move over the 2nd cards GPU, it flows between both cards.) Or would the heat from the 2nd card be traveling upward onto the other card causing the variance?
If pictures would better explan my setup let me know and I ll take some and post. Thanks in advance.
Stay [H]
Stay [H]
