This will be slightly long.
I have a Asus P6X58D-E and one Sapphire 7970 I just got a few days ago.
My mobo has 3 pci-e slots.
The mobo is spec'd to run at 16x/16x/1x or 16x/8x/8x in Tri-Fire. My Dual-X 7970 is so wide though that using it in slot 1 I would not be able to use slot 2. I got my 7970 for a steal of a deal from a local ebayer who cut me a deal since it was local pick up. Just $120 and he has more. So I'm thinking ok. Get another 7970 from him for $120 and just throw it in slot 3. It'll run at 8x and from everything I've read there would be extremely minimal performance loss dropping down from 16x to 8x.
Then I came across this: http://www.overclockers.com/forums/showpost.php?p=6532056&postcount=5
I'd be stuck in the third lane limited to just 1x if I only use slots 1 and 3. While 8x doesn't suffer from performance loss compared to 16x, surely 1x would gimp that second card badly.
This leaves me thinking I'll have to find another smaller 7970 which I would run in slot 1 and then putting my existing wide ass 7970 in slot 2. Right?
I was riding a little old 7870 until this week. Seeing the fire sale on 79xx cards I choose to go that route over a single 290. I mean if I could make the 2nd card work and fit I'd have scored 2 7970's for $240. That is quite a bit cheaper than any 290 I can find not to mentioned superior framerate in ever game I actually play. But now I'm probably looking at trying to find something like the MSI or Gigabyte 7970 which will not impact the second pci-e slot. Sadly, the MSI and Gigabyte cards like most other 7970's on ebay right now are selling in the $175 range. I had originally given myself a $250 budget and was planning on just getting a couple 7950's as those frequently sell in the $125 neighborhood. Then I found this local guy will the killer 7970 deal so I went that route for the first one and I was going to get a second next time I get paid.
Anybody see things differently from how I'm seeing it? I know someone is going to say sell that 7970 for $150 and just get a 290 and that has crossed my mind. In the end though 2 7970's are better performing than a lone 290 especially if the cost is virtually the same or even cheaper to get the 7970's.
Unless I get a 7950. I believe the 7950 will Crossfire with the 7970 yes? There are plenty of MSI or Gigabyte 7950's going for less than $130. In fact there is another ebayer in my town selling 7950's at $130 and I imagine if I played my local pick up card I could get one at $120 or less. I'd have to put the 7950 in slot 1 and the 7970 in slot 2 that way. I was under the impression the superior performing card should be in slot 1 though.
So I guess I'm looking at:
1- Buy a thin 7970 for slot 1 and move my current 7970 to slot 2. This probably takes me out of my original budget plan.
or
2- Buy a thin 7950 for slot 1 and move the 7970 to slot 2. This surely will keep me on budget.
Unless this info in the above link is wrong and I can go slots 1&3 without slot 3 dropping down to 1x with just 2 cards.
My mind is all over the place on this. Kinda looking for some direction. Any help is appreciated. Thanks
or
