Crossfire 6950's psu?
zod96
Suspected BAD TRADER
Would a Seasonic Xseries Gold 750 watt PSU be enough for crossfire 6950 2gb?
Yep. You may want to splurge for an 850 to cover overclocking and future upgrades though.
Ample, you can even run two HD6950s off a 550W PSU (and that includes having an overclocked processor), so 750 is plenty.
550W would be pushing it too much for long term use, but it may work for a while. My rig pulls ~550W from the wall at full load on CPU & GPU. 750W PS works like a charm for me with CF 6950s.
550W from the wall means no more than about 490-500W out of the unit though. That may be high but it's well within tolerance. I measured a system with a 286W card (4870X2) and an overclocked Q9550 to be 390W out of the PSU, so two HD6950s, which is really no more than 340W unless they're overclocked, suggests with a moderate quad core overclock, you're not likely to see more than 450W out of the PSU.
I'm running a coolmax 950watt with a Sandybridge @ 4.6ghz, 2 6950's unlocked to 6970's, 4 velociraptors, an ssd, a 1.5tb hdd, and 8 fans so I think your probably fine.
Despite how it looks, that lot's probably only 500W of draw out of the PSU. Just as well, with a coolmax!
Running my 6950's and 2500k at 4.8GHz off of a 650w Seasonic- no worries. ~500w max draw at the wall.
