crossfire 6870's, please help me decide which driver?
newls1
I will be doing a fresh win7 64 install and setting up my 2 6870s in CF, if you had too choose what driver to use, would u use the 11.1a hotfix or the new 11.2??? Having a hard time deciding.. thanks
i would go for the 11.2 first and if there were problems i would try the older ones.
I'm running 11.2 and haven't looked back. I've got a weird glitch in BFBC2 that the menus have yellow bars surrounding them, however none of the gameplay has changed at all. Whatever you go with, the new CCC is so much easier to get around and so much more logical than the old one, however I haven't been able to set profiles yet with it (I'd like to set low power / productivity and then a high power / gaming /eyefinity profile), so that may play into your choice.
im using the 11.2 now with my single card, and im getting a bsod that reads "hardware unable to connect" error every now and then, so Im really thinking about going back to the 11.1a driver as it was flawless, but really was hoping for some good feedback here
I just got a Sapphire 6870 last week and have been stable with 11.2. BUT, I ran 3dmark 11 and got P2773. Thats with my x6 at 3.6, not sure what's going on.
