Crossfire 2x 3870's or one 4850?
Me_XMan
I'm in position to get two used 3870's for crossfire for about $180.
Close to price of one new HD4850. Is this better than one HD4850?
TIA.
Older gen cards in crossfire/SLI suffer worse from stutter from what I have managed to find.
So far I havent come across any evidence that micro stutter occurs on the 4870 or 4850 in crossfire but am keeping my eye out.
I wouldnt touch the older series of NVidia or ATI cards in crossfire though.
4850 for sure. it'll probably match 2 x 3870's alone and certainly with AA and AF cranked up, it will beat it
Buy the 3870's, eBay em, then get a 4850 for net cost of ~$100 :D
Also though, you have to deal with the whole crossfire thing, and if you don't have a crossfire mobo you're going to need one. Plus single card solutions are always better for various reasons: heat, support, etc. Also, the newer cards allow an easier time for future upgrade and expansion.
I would recommend the 4850, but that's just me. ;)
It might be slightly better than 1 4850 in some games, but then you could always add another 4850 later if you already are thinking of using CF... I would keep reading reviews as many that I've seen put the 4850 neck and neck with 2x3870...
I'd think one new 4850 today is a better buy than 2 used (abused?) 3870s... better single card today and when you want to try Crossfire you'll have a screamer..
For $19 more you can get a heck of a lot more performance (Look at the 3870X2 vs 4850... 4850 FTW). Plus you don't need to worry about two video cards.
Does quad Crossfire even scale well?
I would ebay the 3870s and buy a 4870 with that money.
I would suggest buy single Radeon 4870 , same performance as Geforce 200 series and later on u can upgrade to radeon.
