Cross Fire Wattage question?
Kato1144
Hey I was about to buy a second 6950HD 2GB to cross fire it but im concerned about the power consumption for my 900 Watt ASUS Gamer Power supply, and i did some math based on stats i found on the net on all my hardware and came up with 920 watt theoretically anyway will i be ok even if I overclock or should i just not do it?
Stats
6950HD 2GB HIS
i7 Core 2600k @ 3.4GHz
8GB Corsair vengeance ram
ASUS P8 Z68-V Pro MOBD
2x Kingston 60GB SSD HDD
1TB Segregate SATA
ASUS 900 Watt gamer current edition or something like that.....
it says its SIL ready so i hope it will be good....
900W should be more than enough to run a pair of 6950s plus the rest of that gear.
a Good 750W can power 6950 2gb crossfire
so yes 900w is more than enough
I would give the Antec EarthWatts 650 a go with 2 , 38 amp rails. Just use the 6 pin adapters.
A overclocked 2500k uses only about 120 watts and the 6950's will use 375 watts.
I bet it will easily work.
thanks i will do it ordering the card now
of btw it has to be the exact same card manufacturer and such eh?
I have 6950 tri fire flashed to 6970 volts, watercooled system dual pumps, 2500k @5ghz and average around 700-800 watt usage on load.
No, they can be from any manufacturer. You can even crossfire it with a 6970 though the 6970 will run at the 6950 clocks. Crossfire does not have the limitations of SLI.
If your PSU can put out a constant 900W you'll be fine. My sig rig when stressed fully with OCCT PSU test draws 850W DC.
Rig in siggy.. full load (100% GPU & CPU) using kill-a-watt at outlet =525w. Idle 130w.
