Critique this build, please..
I3eyond
Motherboard: EVGA 680i (http://www.newegg.com/Product/Product.asp?Item=N82E16813188009)
CPU: E6600 (http://www.newegg.com/Product/Product.asp?Item=N82E16819115003)
RAM: CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) (http://www.newegg.com/Product/Product.asp?Item=N82E16820145168)
GPU: EVGA 8800GTX
Soundcard: Audigy 2 ZS
OS: Vista Premium
Case: Thermaltake Tsunami Black (no side window) (http://www.newegg.com/Product/Product.asp?Item=N82E16811133137)
^^Will this case be okay for a college dorm? Also, am I going to have a problem with 3 hard drives and my 8800GTX?
**Will my Antec TruePower 2.0 have any problems running this rig? (550watt)
go with the patriot sticks. no need for the audigy zs, unless you're an audiophile... and if you are, you'd go with an x-fi. why wouldn't that case be ok for a dorm? not flashy enough? no sidewindow = !1337 ?? lol ... or do you mean is it quiet enough? if you want a more quiet case, go with the sonata ii or centurion 534... dont forget a good hsf, like the tuniq tower or scythe ninja. the loudest thing in that system would be the vidcard.
also, call antec and find out if your psu was part of the bad batch of psus they shipped out last year. if your's is older than that, how old is it? hehe... if its too old, you might want to replace it. if its newer than last year, then you should still check.
