First off this will be a WORK machine. It will be used for Quickbooks, MS Word, MS Excel.
The only games to be played on it will be Solitare. There will be No overclocking what so ever.
Now My Choices.
They want SFF So I picked This
BIOSTAR IDEQ 210M Intel Socket 478 Intel Pentium 4 $168.00
http://www.newegg.com/Product/Product.asp?Item=N82E16856115016
Now I'm Torn between CPU's. We want Cheap. Sub $100 would be best. So
Intel Celeron D 325 Prescott 533MHz FSB 256KB L2 Cache Socket 478 $71
http://www.newegg.com/Product/Product.asp?Item=N82E16819112188
Theres also the Cel D 345 at 3ghz. And this
Intel Celeron M 370 Dothan 400MHz FSB Socket 478 $117
http://www.newegg.com/Product/Product.asp?Item=N82E16819112209
Now after adding extra stuff up I can build one with the 71 dollar CPU for
$725 With 1gb memory, 80gb hd space, cd burner, 19" Jetway LCD
What I was planning to build before was an AMD Sempron64 2600+ System with same specs, it came out to $785
With this savings I could up the memory. Or leave it as is. My question is. Whats performance like on Celery D's? I havent built a celeron system in years and havent kept up with Intel Cores much. Would it compare much to the 2600+ 754?
Now My Choices.
