Critique my setup PLEASE
Rusty4560
Getting ready to set up a new machine and these are the parts I have.
(2x) XSPC RS240
(1x) FluidXP+ Magnum Pump
(1x) XSPC Raystorm CPU Block (4770k)
(1x) EKWB-Acetal+EN (Nickel) (GTX680)
(1x) Innovatek Fass-o-Matic reservoir
PrimoChilll 1/2in. Rigid Tubing
I was thinking..
Res -> Pump -> Rad -> CPU -> Rad -> GPU -> Back to Res
Thoughts?
First of all, it makes no difference whatsoever in which way you set up your WC loop. The main thing is you have to make sure you always have water in Res, preferably above the pump.
Get a D5 variant pump. Everything else looks fine.
Thanks,
The res will be the highest point or likely even with the video card. Is there something wrong with the pump I have or do you just prefer the D5 pumps?
