Hi there - I've been trying to choose components for a while. The release of the 8800GT finally made things easier though. How does this look?:
Intel Xeon X3220 G0 Stepping 2.4GHz $283.00
EVGA e-GeForce 8800GT SSC 512MB $299.99
Crucial Ballistix 2GB (2 x 1GB) DDR2 800 $89.99
Abit IP35 Pro $184.99
LIAN LI PC-61 $99.99
Corsair HX series 620W $145.90
2xWD Raptor 37GB in RAID 0 $99.99 each
Asus SATA DVD burner $32.99
I already have two 1TB hard drives - I'm thinking I'll use one for internal storage and the other as an external backup solution. I'd put my software/OS on the RAID array and back it up regularly to one of the 1TB drives, as RAID 0 makes me a bit uneasy. The RAIDed raptors are probably serious overkill - would there be a more cost effective/quieter solution? This computer is for:
What do you all think? Thanks!
edit: I should mention that this is an update to this thread: http://hardforum.com/showthread.php?t=1231054
- eCAD
- SPICE (electronics simulation, the most CPU intensive thing that I do)
- 3D CAD
- programming
- movies/music
- occasional gaming
