Critique my PC
digitalgunfire
Built plenty of machines before, I'm just really looking for someone to say 'I used that RAM in that board and it didn't work well' or 'this board is a better deal' or whatever.. I think I have it pretty well figured out already.
This is for an Eyefinity build if you didn't guess ;)
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - A little worried about this board, I like the specs but I've heard a lot of bad things about it. Thoughts?
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9
Antec P183 - I have a P182 now, really like it, but really open to suggestions here. I hate side panel windows, LEDs, glowing fans, all that junk. I do want to be open to doing Crossfire/SLI later.
Powercolor 2GB 5870 - Should I just get the 1GB? I figured 2GB will futureproof me a bit, especially since I plan to crossfire at some point, plus it means I can hook up all 3 monitors with DIsplayPort.
XFX 750W PSU - Should be enough for Crossfire, right?
Core i7-930
NEC EA231WMI-BK - Contemplating 3 of these for my monitors
Any input appreciated!
Current build is an E6600@3.2ghz, 8800GTX, 4GB DDR2, 24" 1920x1200 monitor - hoping this will be a noticable upgrade ;)
750watt would do it but it will be cutting it close. Get a 850watt model. Everything looks good.
If you're not overclocking whatsoever, that 750W PSU will be adequate for HD 5870 Crossfire. If you are planning on overclocking, even a small overclock, up the PSU to a quality 850W PSU like the Corsair 850TX.
I'd say 1GB should be fine.
+1 750 is gonna be maxing out with crossfire especially with overclock.
I'd go with this G.Skill DDR3-1600 kit instead, its same price without rebate and has the same timings but runs at 1.5v instead of 1.65
I agree with this recommendation. I just hate rebates because more and more companies are now no longer mailing out checks but instead send it to you in the form of a prepaid debit card. And it's all too easy to accumulate overdraft charges when such a card is used.
Thanks for the input, I switched to the GSkill RAM and upped to the 850W XFX.
I figure the XFX PSU is a decent choice, it's made by Seasonic and it's modular, the modular Corsair is more expensive. Looks like it got a good review here on [H] too.
