Well the time has come to build my 4th watercooled pc due to the fact that my current pc in my signature is obsolete.
Here is an old thread on my last watercooled pc:
http://www.overclockers.com/forums/showthread.php?t=465409
Here are my current build specs:
Case: Corsair Obsidian Series 800D
Motherboard: ASUS Rampage III Extreme
Processor: Intel Core i7-930
Memory: Corsair Dominator-GT 6GB DDR3 1600 (PC3 12800)
Video Card: Undecided
Power Supply: Corsair HX Series 1000HX
Operating System: Microsoft Windows 7 Home Premium 64-bit
I will be using my current parts in new build with anticipation of replacing with my new build:
EVGA 7800GTX KO Edition
2 x 36.7GB WD Raptors(Raid 0)
Hitachi 160GB 7200RPM SATA 7K250 Hard Drive
SB Audigy 2 ZS
Vantec 305 Nexus Fan Controller
LG 246WP
I will be reusing my current watercooling parts:
Alphacool Laing DDC Pump
Black Ice XtremeII
2 Sanyo Denki San Ace
Since I plan on overclocking the **** out of my i7-930 I plan on using a dual loop due to the thermal output. I plan on dedicating my one loop using the Black Ice XtremeII radiator dedicated to the processor. I plan on using the EK Supreme-HF waterblock on the cpu.
My second loop will be dedicated with the largest radiator to be used in dual sli overclocked video cards. I have not selected what cards I will be using due to the fact I need to research this area farther before selecting my cards. So I am open to suggestions. I am looking at Danger Den, Swiftech, or EK (in that order, based on pressure drop observations) for full-cover video card blocks.
With a dual loop configuration I am looking at a second pump, second radiator (largest one I can equip on top of the Corsair 800D) case, and a second T-line/reservoir.
I just purchased the Corsair 800D and although it is a great case it does have its shortfalls. I am well aware of having to swap out the rear fan and install it in the reverse configuration to suck in cold air into the case due to the negative air pressure with the stock configuration of exhausting hot air. This is attributed to the shortfall of the one fan on bottom of case not being able to pull in enough cold air to cool the components. My 3 fans on top of the radiator equipped on top of case will be able to exhaust the hot air. This will fall into place with the natural occurrence of heat rising to top of the case.
Thoughts and suggestions on my build are greatly appreciated.
SB Audigy 2 ZS
LG 246WP
Black Ice XtremeII
