I've finally given in to the idea of spending some money to put together a decent gaming machine (My iMac just isn't cutting it in WoW
) I've finalized a system which will fit my needs, but I still want to make sure it passes the [H] test. I've also got a few questions to throw in the mix. Here she goes:
ASUS A8N-SLI Premium ATX AMD Motherboard
Correct me if I'm wrong, but it is FINE to run only 1 video card on an SLI board, right?
AMD Athlon 64 4000+ 1GHz FSB Socket 939 Processor
THERMALRIGHT XP-90C Heatsink
I've read good things about this HS, anyone else using one? If so, can you suggest a fan & size to mount and has anyone had troubles mounting it to the board w/ its weight?
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Dual Channel Platinum System Memory
Western Digital Raptor 74GB 3.5" Serial ATA150 Hard Drive
Primary Boot Disk. This will be my first build using SATA, how does it compare to PATA, not so much as in speeds but in configuring?
Western Digital Caviar SE 250GB 3.5" SATA 3.0Gb/s Hard Drive
Secondary Storage Drive.
BFG Tech Geforce 7800GTX BFGR78256GTXOC Video Card
Antec NeoPower 480W Power Supply
I'm open to suggestions on this one. I've had Antec in the past and haven't had problems, and I really like the idea of being able to disconnect lines that aren't in use. Do you think 480w will be enough to push this?
Thanks in advance guys. Please supply any questions/comments/concern/wth are you thinkings.
Curt
Curt
