Goal: powerful PC for 50% gaming, 50% Media Encoding ( x264, NDAAC, LAME, DVD editing/burning)
This is a tough balance, becuase a 100% gaming rig usually means more OC and less stabilty, where as 100% media encoding requires higher stability and lower temperatures.
I'd also like to keep the sound down to reasonble levels, since it will be on 24x7.
For stability purposes, I don't plan on OCing this PC.
CPU:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775
Scythe SCKC-1000 100mm Sleeve "KAMA CROSS" 3Heat Pipes CPU Cooler
MOBO:
ASUS P5N32-E SLI LGA 775 NVIDIA nForce 680i SLI
RAM:
CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM
Video Card:
ASUS GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16
Sound Card:
Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series
Case:
LIAN LI PC-60APLUSII Silver Aluminum ATX Mid Tower
Power Supply:
Thermaltake W0131RU ATX12V / EPS12V 850W Power Supply
RAID Card:
LSI LOGIC SAS MegaRAID 8308ELP
System Drive:
Fujitsu 36.7GB 15,000 RPM Serial Attached SCSI (SAS)
RAID 5 Array:
3x Western Digital Caviar SE16 500GB 7200 RPM SATA 3.0Gb/s
Newegg Subtotal: $2,876.87
A few of the parts can be had somewhat cheaper elsewhere, but at this point I'm thinking of just buying it all from Newegg.
Well, what do you think?
CPU:
MOBO:
RAM:
Video Card:
Sound Card:
Case:
Power Supply:
RAID Card:
System Drive:
RAID 5 Array:
