HardOCP News
[H] News
- Dec 31, 1969
If you or a loved one has an older Kindle, you had better update the device before March 22nd or you won't be able to connect to the internet. If you wait until after tomorrow you will have to update the device manually.
Important: If you do not update your device by March 22, 2016, you will receive the following message on your device: Your Kindle is unable to connect at this time. Please make sure you are within wireless range and try again. If the problem persists, please restart your Kindle from the Menu in Settings and try again. If you see this message on your device on or after March 22, you will need to manually install the latest software update for your device.
