Critical JavaScript Vulnerability in Firefox 3.5
HardOCP News
[H] News
Mozilla has posted a security warning for Firefox 3.5 today. The company says that the bug was discovered in the JIT JavaScript compiler and disclosed publicly yesterday.
The vulnerability can be mitigated by disabling the JIT in the JavaScript engine. To do so: Enter about:config in the browser’s location bar. Type jit in the Filter box at the top of the config editor. Double-click the line containing javascript.options.jit.content setting the value to false. Note that disabling the JIT will result in decreased JavaScript performance and is only recommended as a temporary security measure.
Another day, another exploit of some piece of software, at least adobe has been quiet lately
Noscript FTW again, because again there is no reason to be running script from xk97fgnnjg-yourbank.com.jnn97hggfd.cn while you are using yourbank.com
Noscript is great, but doesn't help when script is injected into trusted sites. Time to setup the work around.
True, but rarely does bad code come directly from the trusted site. Usually it's some advertiser or inserted code that links to another domain.
True that. Rarely needing java, at least I know when its used, so Noscript is good.
