Critical Errors raining like hotcakes
vader3120
I've got more of the errors in my system event log then numbers in my contact list (ok not really but there are a lot)
Source: Microsoft-Windows-Kernel-Power
Date:
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User:
Computer:
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2009-09-13T11:32:16.426412200Z" />
<EventRecordID>2073</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Sam-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
This is the error i get every time my computer crashes. I dont always get a blue screen, cant get windows to create a minidump, and when the system does automatically restart its about a 50/50 chance that the bios will even load correctly. Half the time i half to manualy restart the system by holding the power button.
i7920 stock settings
Corsair XMS Memory 2gb x2 with stock settings (its 1333 memory, but is running at 1066 and i have played with these settings quite a bit)
GTX260 video Card
ASUS P6T
SSD
Memory is good, ran basic tests again this morning (memtest86 was run a couple weeks ago 2 full 100% passes)
I thought the board was bad, sent it to ASUS, i got my exact board back, said nothing was wrong. All the drivers are loaded, but no updates (i cant get them to download much less install)
In the past week i have been able to run Prime 95 full load for about 65min before crashing. But then again, ive seen it crash 2min into the run as well.
I am running out of ideas, next one i have, is reinstalling windows (Again) and maybe finding a stock HSF
Ill try the CD. I actually bought a new PSU, still had issues, and am returning the extr PSU today. I need to find some extra memory. I am using P6T certified memory but just thought i would see if that was the issue.
