dpoverlord
- Nov 18, 2004
I want better sounding audio than my current setup which is failing at 5.1 sound. I currently have a Bose Cinemate 130 with a Creative X7 LE Soundcard/DAC/Amp that sits under my Samsung 4k SUHD monitor. I recently found out that I was misled in buying the Creative X7 LE to process 5.1 sound to my soundbar(does not pass through 5.1 sound as it does not enode dolby digital).
This leaves me with the unique position to sell my brand new setup at a slight loss(I already spent $2k) or spend $2,150 for the Xi-fi Carrier to replace it. Yes, I am aware how I spent stupid money and I was better off saving $500 and using my Asus X99 Rampage V motherboard audio to pass through sound. Right now its just a $500 kick ass amp for my AKG Annie headphones (it does sound badass).
To be more clear, I can get 5.1 sound on Windows 7 with the bose Soundtouch 130 by running optical from the motherboard to the Bose dock(Acoustimass module). However, in windows 10 Ent LTSB there is no update on my Asus X99 Rampage V realtek windows driver to allow DTS sound. It just does not work with this nor the Creative X7. The X7 LE only works if the audio was already encoded in 5.1 (think of a movie or game as it cannot encode audio and pass it through).
So what should I do? cross my fingers and hope the new Sonic Carrier can be my AIO solution I originally wanted? Or do I bite the bullet and just use this current setup with motherboard sound? I have always been a fan of creatives software suite and it kills me I have this $500 paperweight I cannot use. The Bose I do love for its ability to play spotify and other music apps without turning on my computer. But I would have been able to do that with bluetooth anyways. There truly is no reason for me to have an extra dock sitting on my computer.
Question:
I preordered the sonic carrier for $1750 already but..... Should upgrade? If it is an upgrade from my $2200 current setup (Bose Soundtouch 130 to to the new Creative X-Fi Sonic Carrier 55" 11.1 sound bar. I want 5.1 sound or greater in games and video and could use some guidance to help me out.
links:
Tech Hive Preview
MaximumPC / Pc Gamer preview
Sonic Carrier
Bose Sound Touch Hardware Specs
Please feel free to ask any questions since I am hoping my question is clear enough without this running on. Thanks!
Question:
links:
Tech Hive Preview
Sonic Carrier
System Configuration Main Unit + Wireless Subwoofer
Total Output Power 800W RMS
Peak Power Output 2000W
Weight Main Unit: 16 kg / 35 lbs
Subwoofer: 25 kg / 55 lbs
Dimensions (H × W × D) Main Unit: 90 × 1440 × 145 mm / 3.5 × 56.7 × 5.7 in
Subwoofer: 583 x 530 x 300 mm / 23.0 x 20.9 x 11.8 in
Connectivity Bluetooth 4.0
2x Line level
2x Mic analog input
1x USB host and 2x USB power
3x microSD card slots
1x SD card slot
4x HDMI 2.0a/HDCP 2.2 Inputs
1x HDMI 2.0a/HDCP 2.2 Output
2x Optical Digital In
802.11a/b/g/n/ac Wi-Fi
Up to Gigabit Ethernet
Drivers Main Unit
10x 2.75″ Aluminum Midbass
5x 0.75″ Titanium Super Tweeter
Subwoofer
2x 10″ Drivers
2x Line level
2x Mic analog input
1x SD card slot
Drivers Main Unit
Subwoofer
2x 10″ Drivers
Specs
Dimensions/weight
Console rear panel
Dimensions/weight
- Soundbar speaker:4.9" H x 36.8" W x 2.4" D (7.8 lbs)
- Acoustimass® module:11.3" H x 7.6" W x 14.8" D (13.8 lbs)
- Control console:2.5" H x 12.3" W x 8.2" D (3.28 lbs)
- Remote:8.8" H x 2.1" W x 1.2" D
- Power supply: Dual voltage 100-240
- Wireless range of Acoustimass module: Up to 30 ft
- Supported audio formats: MP3, WMA, AAC, FLAC, Apple lossless
- Shipping weight: 44 lbs (20 kg)
Console rear panel
- 4 HDMI inputs
- Coaxial audio input (digital)
- Optical audio input (digital)
- R-L audio input (analog)
- 1 HDMI output (to TV)
- 3.5 mm connection (for headphones/analog audio)
- SoundTouch® 130 soundbar speaker
- Wireless Acoustimass module
- Control console
- SoundTouch® wireless adapter II
- Universal remote control
- HDMI cable
- Speaker cable
- Power cords
- USB cable (for updates)
- ADAPTiQ headset
