Jul 14, 2008 #1 D dextr3k Gawd Joined Aug 3, 2004 Messages 550 Got a X-Fi Xtreme audio PCIe 1x card. The manual doesnt help much. Which do I plug in? 1) AC'97 or 2) HD Audio Everything says its HD Audio capable, but I cant find anything that says what the front connectors are supposed to be. ><
Jul 15, 2008 #2 D dextr3k Gawd Joined Aug 3, 2004 Messages 550 anyone know what the front panel connector is?
Jul 15, 2008 #3 mrgstiffler [H]F Junkie Joined Dec 20, 2000 Messages 13,408 From what I understand, it's a custom connector. You have to buy an adapter online or make your own to use the front audio. EDIT: Here's a link to a retail one: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=21700 And here's a mod guide: http://img482.imageshack.us/my.php?image=xfifpmodbq5.jpg
Jul 15, 2008 #4 D dextr3k Gawd Joined Aug 3, 2004 Messages 550 Hmmm, i think I have a different card then. Mine is the MSI version, that came with the motherboard. Mine is in the same format as the front connectors:
Jul 15, 2008 #5 K kageon1 Limp Gawd Joined Nov 12, 2006 Messages 173 Deleted Last edited: Dec 21, 2013
Jul 15, 2008 #6 D dextr3k Gawd Joined Aug 3, 2004 Messages 550 Yeah, my antec came with both AC97 and HD Audio, and they both look the same, so I have no clue what to plug in.
Jul 15, 2008 #7 mrgstiffler [H]F Junkie Joined Dec 20, 2000 Messages 13,408 Oh, I see. Well, try out the HD Audio one and see if it works. If it does, SUCCESS! If not, try out the other one.
Jul 15, 2008 #8 C commissioneranthony [H]ard|Gawd Joined Jul 2, 2008 Messages 1,274 what's the difference between ac97 audio and HD audio? does HD audio just have support for an optical port?
Jul 15, 2008 #9 D dextr3k Gawd Joined Aug 3, 2004 Messages 550 I guess I could try out both, I just dont want it shorting somewhere and then breaking the sound card. =( And I have no clue the difference between AC97 and HD Audio.
Jul 15, 2008 #10 D dextr3k Gawd Joined Aug 3, 2004 Messages 550 Turns out it was HD Audio, both ports are working now. Thanks for the help everyone.
