I have the Creative USB X-Fi 5.1 and the THX HD 2.1 cards mainly because my gfx cards covered up the PCI slot.
I noticed on our local auction site the X-Fi Elite Pro on sale for £35, so I got it, I like new toys...
My gfx cards are now running x16/x8 so that I can insert the sound card in between them.
After having some trouble with the drivers, it is installed and works just fine with the console and IR remote handset.
However I have some cheap Altec Lansing 5.1 VS3251 speakers and now there is no sound from the bass power unit or the rear center speaker, so I can't add a bit of thumping bass, but the 4 x F/R satellites work ok.
On the 'Entertainment Mode' there are software controls for bass and treble, so I can alter things a bit.
I know it is an old bit of kit, but I must say the sound in BF3 is totally different from my (new) USB cards, and sounds sharper and better.
I guess there is no cure for this apart from buying another set of speakers ?
Also, as I know sod all about HiFi is this a downgrade from these new USB cards ?
I have only had this Elite Pro running for a couple of days, and if I am happy with it and keep it, I might just sell off the USB cards, or is that a bad move ?.
If new speakers, any suggestions with a budget of around £60-80 ?....nearer £60 would be good.
