Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16829102019 (Card in Question)
I finally returned to creative after 5 years of not using their cards. My last card was a Sondigo Inferno that just up and died a couple weeks ago. I went to Best Buy and picked up the above card and installed it. Everything is running fine as far as I can tell; the card plays audio and drivers are not erroring out -and no sound pops- I'm glad to see creative ironed that out on this PCI-E version. So...
Although everything is working fine, the card seems to be getting very hot. I would say upwards of 60c. I plan on installing a PCI slot cooler.
1) Does the X-Fi normally get this hot during idle operation (not playing sound)? Again, the card hits about 58c Max according to my Infrared Thermometer.
2) Should I switch it out with another Sound Card, or use On-board instead? From what I can tell, the P5Q uses a new Realtek 1200 chip that has good (not great) sound, according to the folks at X-Bit Labs.
