I seem to be having some confliction between my Creative X-Fi Extreme Music and Emu 0404. I have never had any issues with two soundcards installed. Prior to this I had a Audigy 2 ZS with my 0404 installed with no problems. Also had a M-Audio Revolution 7.1 with my Emu installed also without any problems. The problem isn't such that the cards 'don't work' but I can't seem to shutdown my PC. Installing them and getting sound from them both is fine, however everytime I try to shutdown the PC is basically hangs.
This is what I have done (after a fresh install of XP):
1. Installed X-Fi first. Then 0404 drivers. Did not 'overwrite' files. Cannot shutdown PC.
2. Installed 0404 first. Then X-Fi drivers. Same problem.
There is definately some conflict between the cards as my PC will shutdown fine if I disable the 0404 through device manager. Turn it back on and then cannot shut down the PC. Also just to note, the problem occurs mainly when the drivers are installed. If both cards are not recognized in device manager it will still shutdown without any problems.
Any insight on this? I'm sure people around here have both the X-Fi and 0404 installed together, seems like a common combination.
