Creative speakers 4.1
NanaAudio
Hello I have a set of speakers creative 4.1
How connect and configure them for windows 10.
When I test them sound only 2.
Thanks in advance
pendragon1
Thanks in advance
you will probably need a sound card that does 4.1, an old creative card to go with the creative speakers.
NanaAudio
Thanks mr. Pendragon1 for, your time.
Isn't there another way to solve this problem ?
Thanks in advance
pendragon1
How do I set up like 5.1 ?
Thanks in advance.
set it to 5.1, if you have it, in you sound card device properties, under advanced. or in the sound cards control software if you have it installed and then connect them. something like:
